Issue with Form
508
10-07-2021 12:17 AM
ChristopherCharles-Noriega
In Survey123 Connect (3.2.3.0), I'm struggling with figuring out how to delete an unwanted horizontal, 'select_one yes_no' question from my form.
The first row of y/n works the way it should; however, the unwanted y/n row does nothing yet disappears when I select yes on the first row.
I viewed my XLSX file, and I can't figure out what is causing this.
Can anyone suggest what the problem might be?
See attached.
Form 1:  row 41
DeonLengton
Hi Christopher
This issue is related to your other post. You need to fill in the label field of both the Num_RS and "soap" questions:
integerNum_RS
select_one yes_nosoap
Thank you DeonLengton. I appreciate your help.
