ISSUE with Autocomplete interfering with Defaulting Date/Time fields
382
07-20-2017 10:57 AM
DavidRebot
New Contributor II
Hi All,
I'm having an issue where the autocomplete appearance on a select_one field, is causing my Date, Time, & dateTime fields to no longer default to today() & now(), they will come up blank. (All of these fields are within a repeat).
Ex:
typenamelabelappearancedefault
begin repeatSampling_LogSampling Log
dateSampleDateDatetoday()
time
SampleTime
Timenow()
dateTimeSampleDateTimeDateTimenow()
select_one TypeListSampleTypeSample Typeautocomplete
end repeat
Changing the appearance of "select_one TypeList" from 'autocomplete' to something else causes the defaulted date/time fields to function properly.
Do anyone know of a work around for this? I'd like to keep the 'autocomplete' appearance.
Dave R.
JamesTedrick
Esri Esteemed Contributor
Hi David,
I can confirm the issue you are reporting with default values. I've logged an issue for the Survey123 development team to look into this. As a workaround, you could place the functions in the calculate column and they will populate.
JamesTedrick
Hi David,
DavidRebot
New Contributor II
Thanks James!
