Is there any workaround to submit more than one Map Question?
514
07-08-2024 08:41 PM
AndrewCastilloTBSL
I am writing a survey in survey123 web designer, and I noticed when I add more than one map question it defaults to store only one and not the others
Is there any workaround for this?
AndrewCastilloTBSL
I'm not quite sure what you're talking about here honestly.
jcarlson
Probably not in the web designer. I know that you can have multiple map questions in Survey123 Connect and store the other responses as text.
Another approach would be to add repeats to your survey and put the other map questions each in their own repeat. You end up with separate tables for each map question, which could be irritating, but it works.
- Josh Carlson
Kendall County GIS
AndrewCastilloTBSL
Ok so I believe I found a workaround: so, I add hidden single-line text and have them calculate the latitude and longitude based on where they put the point on the map questions. So while only one map in put gets a visual point by default the others will still be recorded in some way.
