Is there a way to zoom in on images in Choices?
654
09-01-2020 09:58 AM
DougBrowning
MVP Esteemed Contributor
When using images in a select one you see a little thumbnail then can tap and make it bigger.  That works great.
But you cannot zoom in at all on the image when it is full page.  Is there any plans to enable this?   We have some image choices where a zoom in would be really handy.
Thanks
by Anonymous User
Not applicable
Hi Doug,
No, this is currently not possible, there is no additional zoom and pan on the image preview for a choices image.
Can I suggest you raise this as an enhancement with Esri Support, or create an idea over on the ArcGIS Survey123 Ideas page.
Regards,
Phil.
by Anonymous User
Not applicable
Hi Doug,
Regards,
Phil.
DougBrowning
Ok thanks just checking if it was already on the list.
Idea is here https://community.esri.com/ideas/19001
Please up-vote.   Thanks
