Is there a way to trigger only the edited attribute info through webhook instead of passing all the information for that record using Integromat?
583
09-02-2022 08:28 AM
Sourish_Beans
I have a Survey 123 form connected with Integromat. It is running well. However, I need to build a scenario that triggers when any new record is added or edited and passes (email in my design) only the edited/added attribute info instead of passing all the fields for that feature/record using Integromat.
Any insights on this will be highly appreciated!
 @JamesTedrick @IsmaelChivite
