Is there a way to open Survey at multi locations to place signatures?
427
05-05-2020 12:14 PM
ErnestQualls
I would like to build a Survey that has multiple Signature Blocks so that it can be opened by different computers to get signatures since they are all at home or offices when we vote on something they can sign that it passed and then when all signatures are on the Survey than it can be submitted. Is this possible?
JamesTedrick
Esri Esteemed Contributor
Hi Ernest,
Depending on the specific workflow, there are a few different ways this could be done.
If this is part of a standard workflow, you could create a series of forms, which show only the signature block for that stage of the workflow and are linked to the same feature service.  We recently shared a technical session from our virtual DevSummit that shows this.
Given that you described sending the form around to collect different signatures, you could also design a form with multiple signature blocks and then only display them based on username using relevant statements.  You could then  share a link to edit the same feature via the webform.
