Is there a way to make public surveys only accessible via a URL?
878
05-01-2023 09:57 PM
JasonRamsay
Hi all,
I'm currently developing a Survey123 form for use by a few people outside of my organisation. These people do not have Esri accounts. So, I was considering making the form public so they can fill in the form regardless. However, I'm concerned about the privacy risks of doing so. The questions on this form contain potentially sensitive information, and I wouldn't want anyone to be able to find the form by, for instance, doing a Google search. I would only want people to be able to find the form with a URL. Is there a way to implement this?
IsmaelChivite
Esri Notable Contributor
Unfortunately, ArcGIS does not allow this at the moment. Once an item is shared publicly, ArcGIS will make it discoverable through its REST API.
Your request is interesting! It sounds as if you wanted something similar to YouTube's unlisted sharing. Is my assumption correct?
IsmaelChivite
JasonRamsay
Hi Ismael,
Thanks for the information. Yes, my question was actually inspired by YouTube's unlisted sharing option. I might have to provide them with paper copy forms.
Andrew_Hooke
Hello, Has there been any update to this?
RobertAnderson3
MVP Regular Contributor
Just came across this now and I feel like it would be a great idea, whether for Survey123 or other apps as well (story maps, experience builders, etc)
