Is there a way to assign a numeric value to multiple classification choices?
548
5
02-18-2019 03:22 PM
MikeChapman
I have a survey form for identifying exposed sanitary lines and a few of the questions have multiple choice options. We have a numerical scoring system we use to give each response a specific number that is used to create a total score for prioritizing work.
Example- "Label" Pipe material? response "ABS", numerical score = 3
                             Pipe diameter? response 15- inch, numerical score 2
        Total = 5
AdrianWelsh
MVP Honored Contributor
Mike,
I think the "choice_filter" option in the XLS form will help make this happen:
Cascading and external selects—Survey123 for ArcGIS | ArcGIS
MikeChapman
Thanks Adrian,  I will certainly give this a try!
MC
AdrianWelsh
I'll be curious to hear if this helped or not.
MikeChapman
The "choice_filter" didn't work in this scenario, I ended up doing a "pulldata" function which did exactly what I wanted 9once I figured out the proper structure LOL!).
MC
AdrianWelsh
Pulldata it is! I'm glad to hear that something worked.
