Is there a back button in Survey123 Connect to return to ArcGIS Collector session?
477
01-07-2021 02:54 PM
KathrynWesson
Can I hop back to ArcGIS Collector from Survey123, to the same feature I was editing, without the use of a URL? I'm looking for the equivalent of a "back button" (like what you see in smartphones when clicking a link within a webpage). Hoping there's a box that I can check in the Survey123 Connect settings instead of hitting the Home button and re-entering ArcGIS Collector through the Home screen.
ClayDonaldsonSWCA
You can add an hyperlink to survey123 form that takes you back to collector:
See this documentation:
https://doc.arcgis.com/en/collector/android-phone/help/deploy-map.htm#ESRI_SECTION1_F7DE2402BA8743E5...
ClayDonaldsonSWCA
KathrynWesson
The hyperlink method is what I'm currently using, but I was just wondering if there's a simpler way that's pre-programmed into Survey123. I'm going to assume there is not. Thank you very much for your response!
DougBrowning
MVP Frequent Contributor
I would use that app switcher, that is what we do.
KathrynWesson
Definitely, thanks! This was just a small detail that was at the back of my mind.
