Is the Vehicle Damage SVG and/or the Human Body SVG available for download?
820
02-03-2020 03:41 PM
JimKyle1
New Contributor II
In one of the blogs the difficulty.svg was provided in a zip file.  I was wondering if the vehicle damage svg and/or the human body svg could be provided as well?   The blog with the sample svg was at; https://community.esri.com/groups/survey123/blog/2019/09/26/using-the-image-map-appearance-in-survey...
Kanin
by Esri Contributor
You can find all the .svg files used in the sample template by:
  1. Open Survey123 Connect.
  2. Going to 'Samples'.
  3. Search for 'image-map' and open the template.
  4. Go to the media folder and you will find all the .svg files there.
       C:\Users\Name\ArcGIS\My Survey Designs\Form 1\Media
Survey123 Connect - Image Map Sample
If this answer is helpful, please mark it as helpful. If this answer solved your question, please mark it as the answer to help others who have the same question.
Jing_Sun
Hello Jim,
I think you can create a new survey in Survey123 Connect using the Image-map sample. You will be able to find the svg files in the media folder.
Cheers,
Sun
JimKyle1
New Contributor II
Thanks.  That was easy!
