Is it possible to transfer an asset location to geopoint question in Survey123 via URL or any other way?
845
11-01-2018 04:40 PM
deleted-user-SoPilc6QQwEP
Hi, I was wondering if it possible to transfer an asset location to geopoint question in Survey123 via URL or any other way?
I am designing an inspection form for electric assets inspection. I am using URL to transfer some field from assets feature service to Survey123 form. I would like inspections location to be as same as assets.
I have assets Lat & Long fields.
JohnathanHasthorpe
Yes, this is possible. You can click on a feature in a web map/Collector and pass in geometry and attributes to a new survey. To pass in the geometry, you would use the center parameter and coordinates:
arcgis-survey123://?itemID=36ff9e8c13e042a58cfce4ad87f55d19&field:surname=Klauser&center=37.8199,-122.4783,20
Please see the following resource for more information: Integrate with other apps—Survey123 for ArcGIS | ArcGIS
JohnathanHasthorpe
Thank Johnathan,
It worked. I used Arcade expression to generate Lat,Long, thanks Kurt for the help with that. Then I embedded them in the URL.
arcgis-survey123://?itemID=4xxxxxxxxxxxxxxxxxxxxxxx&field:FacilityID={FacilityID}&field:LocationID={LocationID}&center={expression/expr2},{expression/expr3}
Configure Attribute in Arcade
This one is latitude:
{expression/expr3}
//wkid 102100->4326
var g = Geometry($feature);
var lat = g.y/6378137.0;
lat = 90*(4*Atan(Exp(Lat)) - Pi)/Pi;
return lat
This one is longitude:
{expression/expr2}
//wkid 102100->4326
var lon = g.x/111319.49079;
return lon
