Is it possible to re-publish a survey after adding a new File type Q?
780
11-17-2023 08:46 AM
LucieS
Hi there,
we've got a live survey (developed in Survey123Connect) and now need to give users the ability to attach files. I hoped to be able to add a File type question to the existing survey but I fear this might not be possible without losing the data. So I was just wondering whether anyone else has faced this issue in case there was some kind of workaround for this?
Lucie
abureaux
MVP Frequent Contributor
I added a file question to my test form and got this:
To resolve this, I...
1. I went to the Feature Layer in Portal, then the Layer:
2. I clicked "Enable Attachments"
3. Then I went back to Connect and was able to publish (Ignore the random additions. The point is the database won't be wiped out):
abureaux
LucieS
just to say a massive thank you- your solution is much simpler than the workaround I was planning on using so very grateful for your help!
Lucie
ChristopherCounsell
If you click 'learn more' it will take you to a documentation page that covers this:
https://doc.arcgis.com/en/survey123/desktop/create-surveys/updatesurvey.htm
Generally it will only prompt to overwrite when a field is incompatible (i.e. string vs integer), or you're adding/updating a repeat (table). Much better than the pre 2.5 days where it always overwrote...
However there is a note on images/attachments:
Image, audio, and file questions cannot be added unless attachments are enabled for the feature layer. If a survey included an image, audio, or file question when it was created, attachments are already enabled.
It looks like Survey123 Connect doesn't have the capability to enable attachments on re-publish, so you have to do it yourself manually.
