Is it possible to create one survey and then edit it using a second survey utilizing the hidden questions from the first survey?
303
08-04-2020 12:48 PM
DonMaxwell
New Contributor III
I would like to create a survey with some questions hidden, then create a second survey to edit those questions later. Is this possible?
ZacharySutherby
Hello Don Maxwell‌,
It is possible to create a second survey to edit those questions later on. What you can do in Survey123 connect is create a new survey based on that existing feature service (associated with your original survey).
This will pull the service's schema and will automatically make those hidden questions into whatever question type their field type is. For example a hidden question that is a string field type will turn into a text question in the survey created from the existing feature service.
If you want the people who are going to be working on the second survey to edit existing records you would enable the inbox for the second survey to edit those records.
Thank you,
Zach
Thank you,
Zach
DonMaxwell
New Contributor III
That's what I was thinking would be the case.
Thanks very much!
Don Maxwell
