IOS Update causing a bug in my survey
558
01-30-2022 10:58 PM
DumisaniNkosi
current survey123 version?
3.13.246
Does the issue happen every time they use the app?
Yes – the App crashes every time the user selects the WPU
please find the attached images of the error and excel document. the survey was working properly but now it has a bug.
Thank you!
by Anonymous User
Not applicable
Hi @DumisaniNkosi,
It appears you are using the web app, not field app, based on screenshot, but you are creating the survey in Connect. Can you send the XLSForm (xlsx file and any files in media folder) so we can see if we can reproduce it?
What version did you last publish the survey from Connect in, and do you use version locking for web form?
Regards,
Phil.
