Integromat scenario is not triggered when the survey is edited
1332
07-16-2019 12:35 PM
YuliaMamonova
Hello,
I currently have 13 scenarios in Integromat that are watching Survey 123 forms. I changed watching module to be triggered when surveys are not only submitted, but also edited, and it's not working. Any thoughts on this?
I should mention that editing is done with survey 123 app, not a web form after the survey was submitted.
Thank you!
Jim-Moore
Hi Yulia
As discussed in this post, could you please confirm if the survey has been updated in the field app since the changes were made to the webhook?
Jim
YuliaMamonova
I think I figured it out, just updating the survey did not work, so I changed the settings for each survey to use the latest Survey 123 version, after that all my edits went through.
Thank you!
