Integromat and Enterprise 10.9 bug
818
08-13-2021 07:29 AM
abureaux
MVP Regular Contributor
Just in case others don't already know, there is a bug with Integromat and 10.9:
BUG-000142104
Integromat webhook configured to listen to a survey submitted in Survey123 set up in ArcGIS Enterprise 10.9, fails when a record is submitted via Survey123 Field App
I am currently using Power Automate as a work around.
ChelseaTabor
I'm new to enterprise and have run into some issues with the survey123 connector in power automate. Did you have to create a custom connector in order to use your survey published with enterprise?
abureaux
Yes!
Here is the article on creating the custom connector in PA for Enterprise: https://support.esri.com/en/technical-article/000025025
Here is an article for troubleshooting when PA starts acting like PA: https://support.esri.com/en/technical-article/000022795
ChelseaTabor
Thanks! That article does a great job going through the process of setting up the custom connector.
