Integrating Survey123 with StoryMaps
428
04-02-2021 10:17 AM
BrandonCrafword
I'm trying to add Survey123 questions from a single survey to a StoryMap. I'd like to have a few questions follow each section of the StoryMap, as opposed to the entire survey waiting at the end. In other words, the survey would be intermixed throughout the StoryMap. Is there a way to place certain questions or segments of one survey in different parts of the StoryMap? I'd like to avoid creating multiple individual surveys of only one or two questions, if possible.
JonathanMcDougall
I've not tried it, however, just a quick thought.
If you create a feature service with all your questions then, using Survey123 Connect, use select parts of that feature service to create your segments creating multiple surveys. That might be an option.
