Integer Field in Survey123 does not allow more than 9 digits
2590
07-27-2018 01:01 AM
geospatialminds
New Contributor II
I have an integer field that I use for a phone number question, the users cannot write into it more than 9 digits, I am also using a pull data function on this field, the number are composed of 10 digits, when the field is automatically filled, it only fits 9 digits. but when we submit the data contains the whole 10 digits, any work around for this issue? I know that using a text field would solve the issue but I dont want the users to to put any text inside the field. Thank you.
CarmelConnolly
CarmelConnolly
geospatialminds
New Contributor II
Thank you Carmel, this is really helpful.
