Integer field in a repeat returns '0' despite entering a value
389
05-05-2025 08:04 AM
ZackHutcheson
I republished a survey using Connect and added an integer field within a repeat. When that question is populated with a value, the resulting value is '0' in the related table. Any ideas why this is?
TylerGraham2
Can you share your xlsx form?  It is doing something if you're getting a 0 because otherwise it would be empty unless you had a default value set.
ZacharyHutcheson
I republished the survey and this seemed to take care of the issue. Not sure why this was occurring the first time around.
