Insert ArcGis Dashboard in a public webpage
864
06-10-2024 03:32 AM
ShareUser
Esri Community Manager
how can I insert an ArcGIs dashboard development in Survey 123?
We need to put this tool inside a public webpage
how can I do it?
Thank you
ShareUser
Can you clarify what you are looking to do?
Do you want a Survey123 form in a public Operations Dashboard, or do you want to display your dashboard in a form?
For the form displaying in a dashboard you will need to use the embed widget. To show a dashboard from the Survery123 form you will need to add a URL in a note field using HTML to create a link.
abureaux
MVP Frequent Contributor
Are you looking to embed a Survey123 form inside of a pre-existing web page?
If so, do the following:
1. Go to the Surveys Site
Surveys Site can be accessed from: https://survey123.arcgis.com/?portalUrl=YOURPORTAL
YOURPORTAL
is the URL used to access your organizations Esri Portal.
2. Locate the survey and click on "Collaborate" icon
3. Look for the "embed in website" button
DanielFox1
If you want to embed the survey into a Dashboard I would recommend having a look at the following community post on this topic
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-embedding-a-survey...
ShareUser
