I have a survey that is used to perform inspections on outfall structures. The setup is a one to many relationship, with one outfall for numerous inspection. I am hoping to use the Survey123 reporting tool, but need to figure out if it's possible to pull information from the parent/origin data (the outfall) to the inspection report.
I attempted to do this following the information in the 'repeats' section of this page https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereporttemplates.htm however this outputs data from ALL of the outfalls, not just the one the inspection pertains to. I figured something like this might work but haven't had luck
${#Outfall} ${if (${ID} == ${Inspection.OutfallID}}) ${LocDesc} ${/} ${/Outfall}
Hi @StaceyHenk ,
This looks a similar case to https://community.esri.com/t5/arcgis-survey123-questions/include-related-records-in-feature-report/m... .
Thanks for the response! I tested out:
${#Outfall} ${Outfall.LOCDESC} ${/}
It returns the LOCDESC of all outfalls in the parent feature class, not just the LOCDESC of the current report. Is there something I need to add so that it only grabs the LOCDESC of the active GlobalID or ObjectID?
I also tried:
${#Inspection} ${Outfall.LOCDESC} ${/}
and received an error:
Error: An error occurred when checking the report template. Failed to parse ${Outfall.LOCDESC} since LOCDESC cannot be found in the current parsing scope.
@StaceyHenk - Did you ever get this working?
