Images not appearing with submitted surveys
273
11-26-2019 01:49 AM
DouglasBradley
The images captured with surveys are not appearing in the data tab or when you interrogate the layer in a webmap. Is this a known issue with surveys submitted recently as my old surveys with images work just fine.
Tags (1)
MikailaBell
New Contributor III
The photos are included as attachments. In ArcGIS Pro, when you right-click on a record in the data table, select "manage attachments" to view them. If you view them through a web map, will be at the bottom of the default pop-up.
