The images captured with surveys are not appearing in the data tab or when you interrogate the layer in a webmap. Is this a known issue with surveys submitted recently as my old surveys with images work just fine.
The photos are included as attachments. In ArcGIS Pro, when you right-click on a record in the data table, select "manage attachments" to view them. If you view them through a web map, will be at the bottom of the default pop-up.
