Image resize
1632
5
11-23-2020 07:04 PM
EricStarn3
Hello all,
I added and image to a note field in connect and am wondering if I can resize it?
It seems to make it very large in the survey. I tried resizing the image but it still filled provided space with large image.
Regards,
Eric
by Anonymous User
Not applicable
Hi Eric,
Have you tried the question height parameter: https://doc.arcgis.com/en/survey123/desktop/create-surveys/esricustomcolumns.htm#ESRI_SECTION1_50827...
I am not sure if this applies to images in a note question, but do know it works for image questions. Otherwise if this does not work, then there is no other way to control the size of the image.
Regards,
Phil.
EricStarn3
Yeah that didn't seem to work, but thank for the insight.
Eric
AnnaScholl
Did you ever find something? I'm having the same problem
BrandonKrejckant
Morning,
I could not find anywhere in Connect to resize an image. But, all I did was use a Google free image resize tool PICRESIZE here, copy over the photo I want smaller, click custom size, entered in 200 pixles by 200 pixles, click resize, then save to PC. From there add that to your media folder and change your names accordingly. This solved my issue 100%. Hope someone else can utilize this as well.
nahomed
You can also try using this resizer.
I like it more than pic resize and others since they dont show ads.
