I have multiple questions in a single row, survey123
324
11-26-2025 08:49 AM
YasnaiaMassie
I have multiple questions in a single row, survey123, which works fine in  the form, but when I publish it to Arcgis Enterprise 11.1 the questions display one question per row.
Here is the excel screenshot, and also in the excel file, settings tab, the column form-style, it's set to field-list
How can I fix this problem?
Thank you
Neal_t_k
MVP Regular Contributor
You need to use a grid format, there are some sample templates in Connect, and here is blog post on grids:
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-groups-grids-and/b...
abureaux
MVP Frequent Contributor
This is the correct answer. I just wanted to drop off a picture.
(Note that you can choose dynamic-grid or fixed-grid)
