I get a parent child send error when I try to sync collected data. The survey includes a nested repeat. Is the problem caused by having a geopoint question embeded in the 2nd repeat?
570
6
10-23-2018 12:30 PM
BethanyCrenshaw1
I get a send error when I try to sync collected data with my survey123 survey.  The error is "This survey was not able to be send due to the following error:  Incompatible feature service.  Parent to child relationship not found from [my survey] (0) to newunit (2)."
The survey includes a nested repeat.  I published the survey using the latest version of Connect, but I am new to repeats.  Could it be the location of my geopoint question?  Thanks!
JamesTedrick
Esri Esteemed Contributor
Hi Bethany,
There is an issue with Survey123 Connect publishing a form where a geopoint question occurs in a repeat after a repeat without a geopoint question (layers get out of order).  This has been addressed for the next (3.1) release - could I ask that you republish the survey with 3.1 beta and try?
BethanyCrenshaw1
Thanks, James! I will try the 3.1 beta and let you know.
Bethany Crenshaw
GIS/GPS Trainer
Forest Service
WO Geosatial Technology and Application Center
p: 801-975-3739
bcrenshaw@fs.fed.us<mailto:bcrenshaw@fs.fed.us>
2222 W 2300 S
Salt Lake City, UT 84119
FS GPS Info<https://ems-team.usda.gov/sites/fs-eng-fdamc/technology/Pages/default.aspx>
Geo Training<http://fsweb.geotraining.fs.fed.us/www/index.php>
www.fs.fed.us<http://www.fs.fed.us/>
<http://usda.gov/>[Forest Service Twitter]<https://twitter.com/forestservice>[USDA Facebook]<https://www.facebook.com/pages/US-Forest-Service/1431984283714112>
Caring for the land and serving people
BethanyCrenshaw1
Hi James,
I installed the Beta and republished the survey.
(By the way it was awesome that in the beta Connect I didn’t have log into AGO, it recognized I was already logged in!!)
When I tried sending the data from the field app on my device I got an error, this time it was a data rollback error. See attached.
Bethany
JamesTedrick
Hi Bethany,
I would need more details on why the operation was rolled back (that indicates that something did not get added properly in the process).  Just to check, did you redownload the form after the republishing?  When the republishing, did it warn you about overwriting the existing feature service?
AmyHaas
Hi James - I'm trying to do this in Survey123 with the beta version you mention above, but without success.
begin repeat 1
geopoint
text 1
text 2
begin repeat 2
end repeat 2
end repeat 1
In theory, is this supposed to work with the beta version?  Thanks, in advance, for your reply.
Amy
AmyHaas
I am experiencing the same issue and as you suggested above I downloaded the beta version to try.  I still get the same error, though.  See attached.
