I can't get predictive text and multiline text working at the same time on Survey123 on Android app.
5380
10
01-07-2019 02:33 AM
RobertMoore
Predictive text has been disabled on the Android Survey123 app by default. How do I get predictive text working for multiline text fields through the Survey design spreadsheet. At the moment, it seems to only be allowing 1 or the other to be enabled at a time. This is very frustrating for myself and the users.
MichaelBruening
So this will "only" work if this appearance type of "predictivetext multiline" is used the very "first" time the survey is published? This is a huge bummer as being able to see the entire text string while using the "speech to text" function would be a huge help for our field crews like it used to be way back in the day.
Have you noticed if you add new questions will this work for them or is it the overall survey itself?
