I am adding depth from and to to my survey. How do I add a constraint on depth to to ensure it is greater than Depth From?
330
01-28-2020 09:54 PM
CraigGadaloff
New Contributor II
BenTurrell
Occasional Contributor III
Hey Craig Gadaloff‌,
You can use the constraints field and the select function to achieve this. Here is a super simple version:
constraint = ".>selected(${Depth})"
This will display a message if your input is greater than the depth.
Ben Turrell
If this answer has helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
BenTurrell
Craig Gadaloff‌,
Did that work for you?
Ben
CraigGadaloff
New Contributor II
Thanks Ben
