HTML Style Sheet to Increase Survey123 Connect Fonts
332
03-10-2023 11:04 AM
StevenHughes44
New Contributor II
I have some survey users that feel that the default size of the question font is too small.  I know that I can add HTML tags for each individual question.  Is there a way the create a style sheet that would apply to all of the survey questions?
ZacharySutherby
Hello @StevenHughes44
It's not possible to apply a uniform text size to an entire form, but if your users are using the Survey123 field app they can increase the text size from the Settings and when they load the form the text size will be larger.
Thank you,
Zach
AdamGaudet
New Contributor III
I had this same question a moment ago. I would like to have a "change uniform font size" feature in that we have some larger forms in which we are trying to "fit" into a single "page" so that the user doesn't have to scroll up or down on their devices to enter information. The previous tool we were using (and trying to mimic) for our data entry had relatively smaller fonts (which no one seemed to mind and actually prefer after showing them what I had put together in Survey123) and as such all fields and drop downs were able to be viewed a single medium-sized tablet screen. As we are trying to duplicate this previous layout (as per the users request), I'll have to put HTML tags before every field which is annoying and slows down my workflow.
