HTML formatting issues in Survey123 Connect
256
04-02-2019 09:11 AM
deleted-user-IDFw933hiTUM
Here is the xls form info:
<b><u>${prevalencetest_sum}</u></b> 3 - Prevalence Index is less than or equal to 3.0<sup>1</sup>
and here is what it looks like in the Survey.
Survey123 underline issue
It is putting the underline as a strikethrough in the "N" and I think it's because of the <sup>1</sup> at the end.
I have two other lines like the one above and they work fine, but they don't have the <sup> at the end.
Any ideas on how to fix?
Thanks much!
JamesTedrick
Esri Esteemed Contributor
Hi Lisa,
I can replicate the issue you are describing and have filed an issue to investigate and resolve.
Thank you!
