Hello!
I'm trying to set up a survey to be used for employees to take as an online test. The test consists of multiple select_one/select_multiple questions and each question has one or more right answers. I would like to assign the right answers a score of 1 and tally the results using a hidden score field to know if the users passed or not. What would be the best way to go about accomplishing this?
Thanks!
Typically for this you have a corresponding calculate type row for each question. This field does something like if(${field1} = "Correct answer", 1, 0)
For select multiple you need to use selected and then an or if there is more than one correct answer if(selected(${field1}, "Correct answer") or selected(${field1}, "Correct answer 2"), 1, 0)
At the very end you can add them all up. ${Check1} + ${Check 2} ...
Make sure to set the bind type field to int on the checks so that your final answer does an add and not a concat.
Hope that helps
Hope that helps
perfect! Thanks @DougBrowning
Hey @DougBrowning ,
Do you have a method for tallying up a select multiple with each selection having a point associated with it?
For example:
"Which Equals 4?"
A. 2+2
B. 1+3
C. 3+1
D. 5-1
I would like to assign each of these a point so the question total would equal 4 points. Currently the question is set up to be a single point for the entire question.
Thanks.
I think I know but you mean but not positive.
In your simple example all answers are correct so just count-selected(${previous_question}) would work.
But if you have to test each one then all I can think of off the top of my head is to have 4 fields.
if(selected(${field1}, "Correct answer"), 1, 0)
if(selected(${field1}, "Correct answer 2"), 1, 0)
etc. Then add those 4 fields up. Of course this can get really long depending on the list.
Hope that helps.
Hey @DougBrowning worked exactly as I needed. Thanks again for the help!
