Hi! I'm a beginner here, so my question may have a straightforward answer (I've searched online with little success prior to this). I've conducted a survey with Survey123 in two different fieldwork locations. Now, I have all the data on one survey, but I want to compare the data from each location. Should I try to separate the data into two different surveys? If so, how should I do this, as I've had little success so far. Thanks very much
Hi Oliver,
I replied to you other post which had the same question, here: https://community.esri.com/thread/226713-how-do-i-separate-data-that-ive-collected-in-one-survey-int...
Phil.
