I made a storymap for a project (https://arcg.is/1nyy9O) whereby the public can also add information using Survey123.
so
1) I made a survey, both 'submit' and 'analyze' for everyone (public).
2) The data as results I put in webmap - made it public as well
3) of that webmap I made a web app , made it public as well
However the results of that survey I put in a webapp (tab 'Crowd observed dangers' in the story map), can't be seen without being logged in to ArcGIS.
Can his be solved as it should be freely visible for everyone.
Hi Luc. Did you figure what the problem was? Looking at your Crowd Observed Dangers tab I can see some points, which I highlighted below using black squares. Are these all points you expected to see, or are you missing points in there?
