How to make conditional questions in connect?
10185
12-01-2022 12:01 PM
cole_KTB
Hey there,
I am newer to using Xls forms with Connect to make surveys. I want to make an additional question to appear in the survey upon the user selection a certain option in a multiple choice Q. Else wise I would like for this to remain hidden.
I came across this: if(condition, a, b) If the condition evaluates to true, returns a; otherwise, returns b.
This could probably work for my purposes, but I do not know which column to implement this code in, nor how to set a & b values appropriately.
Thanks in advance for any help you may be able to provide!
jcarlson
MVP Esteemed Contributor
That is the function of the relevant column. You can read more about it in this article: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-hidden-relevant-an...
Basically, on your conditional question, put an expression in the relevant column that evaluates to "true" or "false". Like selected(${question_1}, 'a').
- Josh Carlson
Kendall County GIS
cole_KTB
Thanks Josh this definitely helps.
I have an additional question to go along with this, using the ${q1}='x' conditional function in the body::visible, will this work properly with "select_multiple" questions? I would like to include this conditional Q if X is selected alone OR along with X, Y and Z etc. How would I write this expression? ${Q1} = 'X' or 'X + Y" + etc... I am not fimiliar with XLS form language.
cole_KTB
I was able to solve this problem using the "selected()" function in the body::visible column!
