Hi there,
I'm trying to work out how to build a survey in the Survey 123 web based drag and drop app and then edit the XLS with Survey123Connect? I'm sure i've done it before by fluke, but can't seem to work out how to do it again.
Please advise.
Hi Andrea,
After publishing the survey on the web, you should be able to access it in Survey123 Connect - you will download it to your computer; then you can edit it.
