I want to start using Survey123 in conjunction with Collector, but I cannot find a way to download the Survey123 Connect application without creating a separate ArcGIS Online account.
Is there a way to download and use Survey123 Connect, or will I have to create an AGOL account?
Hi Eric,
Can you try the account username you use to access my.esri.com?
This is the pop-up that I get when I try and sign in with my my.esri.com Organization account.
Thanks Eric, I suspected that might be the case. We'll work to address this issue.
Has this issue been addressed? Through my job I have a Portal for ArcGIS publisher account, but am unable to log in with that account and download Survey123 Connect.
Hi Aaron,
We're working with the documentation team to update the download page; in the meantime you can access it via https://esri.box.com/v/Survey123Connect
Hey James
Any progress on this? I see there is a more recent version available.
