How to display image dependent on select_one answer
108
08-07-2018 08:40 AM
Occasional Contributor III
I want to display an image in the survey based off the answer given in a select_one question.
eg: ${structure_type}='Hooded Catch Basin, then it would display
That way the users know they have selected the correct Stormwater Structure.
Esri Frequent Contributor
Hi Carl,
Do you want to display the image as part of the select_one questions as a reference, if so this is supported and possible. Please see the Media sample available in Connect, as shown below.
Alternatively you can also set the default image for a draw/annotate question type based on a previous answer to a select_one question, see the Photos and Smart Sketching sample for an example of this.
Regards,
Phil.
Hi Carl,
Regards,
Phil.
