Good morning,
I am looking for a way to create a copy of my current survey and modify it for editor/reviewing purposes.
I am trying to create a Dashboard, but I do not know how to create a survey to review requests
Survey123 Tricks of the Trade: Embedding a survey in an ArcGIS Dashboard (esri.com)
Thanks
Solved! Go to Solution.
Do you want this new "copy" to see all the data submitted by the original survey? In that case, you want to link both (which would make sense - I use this workflow a lot). The easiest way to do that is open Connect > + New survey > select Feature services > search for and select your original survey > click Create. You now have a child survey that is linked to the parent survey. You can remove fields from this child, but you cannot add fields (add them manually to Portal, or with ArcPro, or with Connect to the parent survey).
EDIT: And I should mention that this workflow requires the Inbox.
I've had to explain this a few times in the past, and each time it is convoluted and annoying to do so (The process is relatively simple, but it's not intuitive). As such, I created a video outlining the basic steps. I tried attaching the video. Hopefully it makes sense. I may need to add in the keyboard shortcuts I used.
I tried to create a new Survey selecting in Feature services the current one, but the results loses all formatting and fields are not on the same order.
Is there a way to duplicate an existing Survey and point to the same Feature service?
Thanks
You can replace the content of the generated xlsx file with lines from the original survey to bring them back to functioning the same. Fields just need to line up exactly (names, types, length). You can reorder how they are displayed on the form without issue.
This is the solution.
Typically what I do is I follow my above steps, but after the child survey is created:
