How to create a Survey to review requests not to submit
1056
6
07-26-2024 06:16 AM
SanchezNuñez
Good morning,
I am looking for a way to create a copy of my current survey and modify it for editor/reviewing purposes.
I am trying to create a Dashboard, but I do not know how to create a survey to review requests
Survey123 Tricks of the Trade: Embedding a survey in an ArcGIS Dashboard (esri.com)
2 Solutions
abureaux
MVP Frequent Contributor
Do you want this new "copy" to see all the data submitted by the original survey? In that case, you want to link both (which would make sense - I use this workflow a lot). The easiest way to do that is open Connect > + New survey > select Feature services > search for and select your original survey > click Create. You now have a child survey that is linked to the parent survey. You can remove fields from this child, but you cannot add fields (add them manually to Portal, or with ArcPro, or with Connect to the parent survey).
EDIT: And I should mention that this workflow requires the Inbox.
abureaux
I've had to explain this a few times in the past, and each time it is convoluted and annoying to do so (The process is relatively simple, but it's not intuitive). As such, I created a video outlining the basic steps. I tried attaching the video. Hopefully it makes sense. I may need to add in the keyboard shortcuts I used.
abureaux
SanchezNuñez
I tried to create a new Survey selecting in Feature services the current one, but the results loses all formatting and fields are not on the same order.
Is there a way to duplicate an existing Survey and point to the same Feature service?
DuncanC
You can replace the content of the generated xlsx file with lines from the original survey to bring them back to functioning the same. Fields just need to line up exactly (names, types, length).  You can reorder how they are displayed on the form without issue.
abureaux
This is the solution.
Typically what I do is I follow my above steps, but after the child survey is created:
  1. Copy-paste the Parent XLSX into the folder with my new Child XLSX
  2. Copy over the "settings" tab (specifically submission_url and form_id) from the Child XLSX into the Copied Parent XLSX
  3. Delete the old Child XLSX
  4. Rename my Copied Parent XLSX to be whatever the deleted Child XLSX was, effectively making it the New Child XLSX. As soon as connect sees the newly renamed XLSX as a different time-stamp from the old XLSX with that name, it will refresh and you will have a fully formatted XLSX to work with.
abureaux
SanchezNuñez
Hi @abureaux
Thank you very much for sharing a video!!!!
Regards
