How to Constrain Geopoint Locations?
3486
11-20-2016 06:55 AM
BradWells2
How could I set constraints on geopoint lat/lon data in Survey123 Connect such that responses are limited to a rectangular area?
I have tried to use an expression similar to the following to accomplish it, but to no avail.
((pulldata("@geopoint", ., "x") >= -##.#### and pulldata("@geopoint",., "x") <= -##.#### ) and (pulldata("@geopoint", ., "y") >= ##.#### and pulldata("@geopoint",., "y") <= ##.#### ))
Any ideas?
BradWells2
I have resolved the issue by moving the constraint to a calculate field based on the lat/lon of the geopoint field.
BradWells2
NealeHutcheon
Brad,
I'm trying do something similar.
I tried this in the geopoint constraint using separate pulldata functions but it still allowed all points to validate even if outside the range of lat/lon I set.
geopoint constraint (${X_Value}>140 and ${X_Value}<150 and ${Y_Value}>-39.2 and ${Y_Value}<-36)
where
X_Value calculation pulldata("@geopoint",${location},"x")
Y_Value calculation pulldata("@geopoint",${location},"y")
 Can you see where I've got this wrong ?
FlorentBigirimana
Hi Brad,
I have done something similar by
1. creating an external choice table with rectangular  coordinate field a of my working area as a string  (working area, x_min,x_max,y_min,y_max)
2.creating a fields x_min, x_min,x_max,y_min,y_max  populated by the substr function from the working area coordinate string
2.created field, in my survey of latitude and longitude populated by the pulldata@geopoint  function
3.made the following calculation ${longitude}>=${x_min}and${longitude}<=${x_max} and ${latitude}>=${y_min}and${latitude}<=${y_max}
So this is working fine for me
