How to compare dates with arcade calculation in Survey123?
1221
03-27-2020 11:48 PM
RobertBuckley1
I have a survey which records the date when a record is created.
Would it be possible to somehow have a dynamic field which is parsed at run time to record either a 1 or 0 to see whether the record was made today? Obviously If this was calculated when the record was calculated it would be always 1.
JamesTedrick
Esri Esteemed Contributor
Hi Robert,
This can be done in a couple of ways.
If you need new records in the past 24 hours, look at the DateDiff function and use a if/else block to assign 1/0 based on that: Date Functions | ArcGIS for Developers
If you need to match the exact date, I would use the Day(), Month(), and Year() functions to compare the values to today:
var today = Now();
var theDate = Date($feature.CreationDate);
if (Day(today) == Day(theDate) && Month(today) == Month(theDate) &&Year(today) == Year(theDate)) {
return 1;
return 0;
