How to combine two or more conditional statement in one function?
1860
10-11-2017 07:38 AM
AdministratorAGOL_ODIMM
Situation:
Q1. Select one question with answers A, B, C, D
Q2. integer or hidden question, calculate using conditional statement: if(selected(${Q1},'A'),1,10) OR if(selected(${Q1},'B'),3,10)
giving points in Q2 depending on the response in Q1
A=1
B=2
C,D =10
How to combine this two conditional statement in one function?
NickDierks
You should be able to nest your if/then statements: if(selected(${Q1},'A'),1, if(selected(${Q1},'B'),3,10))
This will run your second if/then as the else case of your first if/then, and if neither condition is met, then the second else case is the final result.
NickDierks
It works, thx a lot Nick!
