How to calculate total hours worked from 2 time fields?
849
05-10-2022 12:55 PM
GISManager4
I need assistance with a formula that takes the values entered from 2 time fields into a total hours work field.Capture.JPG
Attached is the xlsx file
ZacharySutherby
Hello @GISManager4,
Please check out the Dates and Times sample available in Survey123 Connect, the same shows how to perform calculations on dates and times in Survey123.
The calculation that would work for your use case would be (decimal-time(${end_time}) - decimal-time(${start_time})) *24 *60 (calculates minutes elapsed) or (decimal-time(${end_time}) - decimal-time(${start_time})) *24 (calculates hours elapsed).
Thank you,
Zach
