How to Auto populate an End Time in Survey123 Connect
161
12-16-2020 10:57 AM
RReeder
The End Time for a section in my survey is 3 minutes after the Start Time. The Start Time is defaulted to now(). How can I auto populate my End Time to be 3 minutes after the Start Time?
Reply
SarahHartholt
Does it need to be created in the survey or can it be added to the attribute table later?
This might be useful to you: arcgis desktop - Using Field Calculator to Add a Set Amount of Time to Date Field - Geographic Infor...
Reply
RReeder
Ideally it would be auto populated in the survey before it is submitted.
Reply
SarahHartholt
Reply
DougBrowning
MVP Frequent Contributor
There is a field type called End.  Give that a shot.
Reply
