How to add descriptive images to Survey? Wrong format of image
416
01-09-2024 07:33 AM
felixerdy
I'm creating a survey in which I'd like to show descriptive images. I was able to include an image as a note
But the format does not fit within the app. I can't scroll to the right.
Is that even the correct way to add images? How can i fit the width?
abureaux
MVP Frequent Contributor
Is your Connect app up to date?
Long images should scale to the screen (see below)
Small screen:
Large screen:
felixerdy
Well, I'm designing the survey in the browser on https://survey123.arcgis.com/
Do I need to use the Connect App for that? I'm working on macOS right now but I'll try it on a Windows PC soon.
abureaux
Hmm. I tend to avoid the web designer for many reasons. That may be the issue in this case.
If you have access to a Windows system, trying Connect on there will be a good starting point. If you do, be sure to install Connect through the Microsoft Store so it auto-updates.
