How to add bind::esri:parameters column to older ArcGIS Survey123 Connect xslx forms?
1786
5
01-11-2024 08:11 AM
GISManager4
I have several survey123 forms that were created in an older version of ArcGIS Survey123 Connect and want to be able to use the bind::esri:parameters column to the existing xslx document.
Katie_Clark
MVP Regular Contributor
In Connect, there's an option to update the form and will it convert the XLS form to the latest version. You can also just add the column manually and as long as the column name is spelled correctly, the application will recognize it and honor the settings.
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
GISManager4
I cannot find the option in Connect to update the form, but I was able to copy and paste values of the column into the old form. If you could show me where the option to update is, that would help?
DougBrowning
MVP Esteemed Contributor
I highlighted it in red in my post.  Under Tools.   You probably need to go update your Connect here. https://www.esri.com/en-us/arcgis/products/arcgis-survey123/downloads
abureaux
MVP Frequent Contributor
Is your Connect up to date? Older Connects don't have this option.
DougBrowning
You can literally just add the column and it will work.
But also if you upgrade your Connect there is now a way to update in there.
I also posted the old school way to do it somewhere.  Basically start a new form, copy paste values! column by column, save, then swap out the xlxs in the folder.
hope that helps
