How to add a brand/logo to a Survey123 Connect form
2962
07-26-2022 06:05 AM
DuncanG
Hi, I have added a logo to my Survey123 Connect form which works fine on the preview. However, when I share the link to the survey with others the image is not available. I presume this is something to do with the logo being saved locally on my laptop, but I can't figure out any other way to get this to work.
Any ideas?
Thanks
DougBrowning
MVP Esteemed Contributor
You do not put the full path in there.  Just put the file in the media folder then give it just the file name. Like EN_date_invert.jpg  Note the name is case sensitive.
That will work
DougBrowning
That will work
DuncanG
Perfect! Thanks for that, it works fine now.
