How many elements as a list can create Survey Connect?
414
12-03-2018 02:46 PM
RogerMesen-Delgado
Hello, I been working in one cascade list in survey 123 design Connect, but when I check the feature hosted in AGOL the app din't create the list ( domain). The field with more items in the list has 400 elements.
ClaireProctor
Hi Roger,
This looks like an issue with your implementation, rather than the limits of cascading selects or select one questions; I'm not even aware of how many domains can be included as a maximum, but 400 should be just fine. As reference, the autocomplete sample in Survey123 Connect (which doesn't use a cascading select, but is using a select one) has a little over 5900 choices in its choice list without error.
