How i can constrain a datefield to be today or 5 days max before?
1038
6
06-12-2017 08:03 AM
LouisDECOMBE
hi,
Is there someone to help me on constraint with date field.
I've a datefield and i want that the user put a date that would be the d-day or 5 days before the d-day max.
I've tried with : >now() +5*24*60*60*1000, but does not function.
Thank you for your help.
A french guy!
JamesTedrick
Esri Esteemed Contributor
Hi Louis,
So the valid dates are from today -5 days?  In that case you would need a compound statement to set lower and upper bounds:
int(.) >= int(today()) - 5*24*60*60*1000 and int(.) <= today(.)
So it must be greater than or equal to 5 days ago and less than or equal to today.
IsmaelChivite
Esri Notable Contributor
Bon jour Louis.  Attaching an example that worked  for me.
LouisDECOMBE
Hi Ismael,
Thank you for your help. I've tried but still does not function
see in the attached video: https://framadrop.org/r/EtNaumkzlh#FgGTNJK0byjyhHCA4dmY7rWSZVYSq28AGj7emVtR+vQ=
JamesTedrick
Hi Louis,
There seems to be a type conversion issue causing the problem.  can you try the following constraint:
int(.) < int(today()) + 5*24*60*60*1000
The addition should work correctly with everything being an integer.
LouisDECOMBE
Hi James,
Thank you for your answer. I would never find it alone !
It seems to work. But what i wanted to do was to forbidden a date after today and more than 5 days before today
For exemple, we are the 15/06/2017
The user can had 10/06 , 11/06, 12/06, 13/06, 14/06 and 15/06 but not more.
What would be the constrain for that?
Regards
JamesTedrick
Hi Louis,
LouisDECOMBE
PERFECT
THANK YOU VERY MUCH!
It works great
