How do I share a survey with other AGOL users ?
1340
08-18-2016 03:43 PM
FatmaŞenol
I checked Geonet before posting this question and unfortunately, I couldn't find a solution.
I created a survey using Survey123 web and I would like to share it with other users.
Therefore , users could modify the survey using Survey123 Connect before publishing it.
Please note that, all surveys are saved in a specific group and other users are also
member of this group.
The problem is that other users cannot see and download the survey using Survey123
connect. I would be grateful if you could kindly share your experiences and suggestions.
Regards
JamesTedrick
Esri Esteemed Contributor
Hi Omur,
Are the users in the same organization as you?  We don't have access via group support in the connect app yet, but you can access forms shared to them via the 'My Organization' option.
James
JamesTedrick
Hi Omur,
James
FatmaŞenol
Hi James,
Yes, all users are in the same organization.  I managed to access forms shared via my organization
as you suggested. It would be grateful if next version of Survey123Connect supports group access.
Therefore, users could work on the same form.
Best Regards
